I want to monitor multiple Tor Relays running on one server.
Followed the config guide.
Debian 12.6, netdata v1.46.3
The possibility to configure several Tor Relays.
I duplicated the local_socket config and changed the name and the path to the control socket. But Netdata is only monitoring the last Relay. The first one is ignored, despite a different name.
Python version (the one you are using) will be removed in the next stable release (v1.47.0). I rewrote it in golang.
You have 2 options:
Keep using the python version (the existing installation will still have it): you will need to enable it python.d.conf (it is disabled now).
Configure go.d/tor (will be in v1.47.0). I tested it via TCP socket (e.g. ControlPort 9051) + password (not Cookie file auth). It should work via Unix socket too, but I didn’t test it.
