it result that i’m banned from cloud:
i have 2 docker nodes, what can i do?
Hi @spupuz
We have identified an issue on a specific nightly version of the agent (it affects version 1.39.0-97). For more information please check https://status.netdata.cloud/
If your current version of the agent is 1.39.0-97 then the ban is caused by this. Next nightly version will fix the issue. We are really sorry this has affected you.
thanks for the reply will wait the new version
Please how soon would the next version be available? And would it auto update as well?
