Version: netdata v1.34.1
ERROR LOG:
2022-07-11 17:56:20: python.d ERROR: elasticsearch[local] : Url: http://10.1.96.38:9200/_nodes/_local/stats. Error: HTTPConnectionPool(host=‘10.1.96.38’, port=9200): Max retries exceeded with url: /_nodes/_local/stats (Caused by ReadTimeoutError(“HTTPConnectionPool(host=‘10.1.96.38’, port=9200): Read timed out. (read timeout=1)”,))
Please do a wget or curl on the same URL. If it doesn’t respond, then the issue is on the ElasticSearch side.
I did a small search and saw only one prerequisite for the various /stats APIs to work. e.g. for the cluster /stats API, it says:
If the Elasticsearch security features are enabled, you must have the monitor or manage cluster privilege to use this API.
@ilyam8 suggested that the timeout could just be because it’s a remote address and the default of 1sec to get a response isn’t enough. You can add timeout: XXX to your data collection job, to increase the timeout:
From go.d/elasticsearch.conf
# - timeout
# HTTP response timeout.
# Syntax:
# timeout: 1
