Netdata still running even when systemctl service is masked
Suggested template:
On Ubuntu (latest version of the agent)
Netdata shouldn’t be running
I was trying to uninstall (wiped the dirs after) and installed the latest version of netdata
However, I noticed that the netdata installer script installed netdata into /opt/netdata instead. And systemctl service is masked, but the newly installed netdata agent is still accessible.
So now how can I stop the running netdata (the one that’s installed in /opt/netdata dir) properly?
And why during the uninstall, the netdata.service file is not removed? Or is this normal and has to be manually removed by me?
Hi @philip
What version of Ubuntu are you running? In some cases of older Ubuntu’s, the installer might pick a static install to use (what you see in /opt/netdata) if there are no packages for this distribution.
The static install should be controllable from the service file. I would guess in this case that there was something left over from the uninstall. Did you also use the kickstart script the first time you installed netdata?
Hello @Manolis_Vasilakis
Ubuntu Jammy (Ubuntu 22.04)
Service file? Where is it located?
Yes, installed through kickstarter script (stable channel with no updates). Uninstall was done using the uninstall script.
