opensearch does not appear automatically. Is it correct that it doesn’t appear automatically?
Hi, @COBAY. Two questions:
- Does opensearch have the same API as ES? See Used Endpoints.
- What port is the application listening on? ES is 9200.
Ok, I started an opensearch docker container. I see these differences:
- https
- basic auth is needed, default user/password is admin/admin.
The following worked for me:
jobs:
- name: local
url: https://127.0.0.1:9200
tls_skip_verify: yes
username: admin
password: admin
Added that job to the default elasticsearch config in go.d/#1140.
