I have a Parent Node that is connected to Netdata Cloud. There are multiple child nodes connected to the Parent Node. Along with Parent node, all of child nodes are visible in the Netdata Cloud. One of the child node is triggering Alert for filecheck module, on exceeding size limit. This alert is visible on the local url of the child node: http//:child-node:19999 but not on the Netdata Cloud.
child node’s alert window:
Netdata Cloud UI alert window:
The Alert is a custom alert created on custom chart using filecheck module.
Files and directories | Learn Netdata
Restarted Parent node several times.
Parent node: v1.45.5. Running on docker.
Child node: v1.46.3. Running on Linux container.
Netdata Cloud has to show the Alert.
Kindly assist.
Thank you
