Persistent dynamic filters?
Is it possible to make dynamic filters peristent?
Currently i have to set the filters everytime i switch my browser of browser data has been cleared.
Have you tried the user settings on the chart?
This allows the user to save settings for charts. The saved settings will then be the default view for the user:
  1. personal has first priority
  2. room and space settings are shared across the room or space and if there are no other personal settings, the those will be used for the chart.
Thanks for the quick response. I would like to make the following checkboxes persistent:
Global filters cannot be made persistent. Maybe for your use-case it is best to move the things of interest to a new room?
No possible? Can’t believe it. Then this is a feature request.
Please open a feature request here: Issues · netdata/netdata-cloud · GitHub
These user settings snapshots – where do they go? Where can I see a list of them? How do I recall a different one I’ve saved to the chart?
I’ve looked everywhere and I cannot find any interface for these things except the button in your screenshot, which politely accepts the new settings snapshot and the name I’ve given it and files it directly into a black hole.
