Rest API is not update. but dashboard work perfectly fine.
Environment
OS: Ubuntu Server 18.04 LTS
Netdata agent version: v1.32.1-4-nightly
I create a custom webpage to show the status of GPU by requesting chart data from Rest API (nvidia-smi chart).
However, API is not real-time. Data last update was 6 hours ago.
but the agent dashboard (IP:19999) is perfectly working fine in real-time.
Here is how I called the REST API
http://IP:19999/api/v1/data?chart=nvidia_smi.gpu0_user_mem&points=1&=1639718574
Where 1639718574 is the UNIX timestamp. the timestamp will change every time when a request to avoid caching by a browser. but data was still 6 hours ago.
A method to retrieve data from Rest-API in real-time.
Thank you.
&=1639718574 should be &after=1639718574
Hey @pureexe,
did this fix work for you? Let us know if you have any further questions.
The solution @vlvkobal suggests is work!
Thank you.
