Hi
I just set up SNMP on my netdata instance to monitor my switch.
Sadly I just get very very little stats, like just some networking stats, uptime and port status, many metrics are missing which I can otherwise view via snmpwalk.
Cisco is offering a custom MiB file for that snmp monitoring, how do I import that into netdata?
I’m currently using the agent to monitor the snmp device.
Browser: Firefox 130.0
Agent: netdata v1.47.1
buildinfo of that agent:
Packaging:
Netdata Version ____________________________________________ : v1.47.1
Package Distro _____________________________________________ : debian 12
Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
Kernel Version _____________________________________________ : 6.8.8-4-pve
Operating System ___________________________________________ : unknown
Operating System ID ________________________________________ : unknown
Operating System ID Like ___________________________________ : unknown
Operating System Version ___________________________________ : unknown
Operating System Version ID ________________________________ : 12
Detection __________________________________________________ : unknown
Hardware:
CPU Cores __________________________________________________ : 2
CPU Frequency ______________________________________________ : 2800000000
RAM Bytes __________________________________________________ : 4294967296
Disk Capacity ______________________________________________ : 256060514304
CPU Architecture ___________________________________________ : x86_64
Virtualization Technology __________________________________ : none
Container:
Container __________________________________________________ : lxc
Container Operating System _________________________________ : Debian GNU/Linux
Container Operating System ID ______________________________ : debian
Container Operating System ID Like _________________________ : unknown
Container Operating System Version _________________________ : 12 (bookworm)
Container Operating System Version ID ______________________ : 12
Container Operating System Detection _______________________ : /etc/os-release
Features:
Database Engines:
dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
Libraries:
libmnl (library for working with netfilter) ________________ : YES
Plugins:
Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
I expact a way to import a custom MIB file or get more metrics by default.
