SNMP Plugin vNode problems
So I’ve set up SNPM monitoring to scrape my switch, that worked great using these commands and config:
cd /etc/netdata 2>/dev/null || cd /opt/netdata/etc/netdata
sudo ./edit-config go.d/snmp.conf
jobs:
  - name: CiscoSG300-28
    update_every: 50
    hostname: "10.50.20.2"
    community: public
    options:
      version: 2
I got the metrics to show up on the netdata UI under that node.
No as that node is the parent node, it would be nice to have the smtp device listed like a real device, as it technically also is a seperate device.
I found the vnode section, I append it to the config:
jobs:
    create_vnode: true
    update_every: 50
    community: public
    options:
      version: 2
And restart the netdata agent.
However NO new node is on the dashboard, no matter what I do, what am I doing wrong /missing?
Also why does SNMP not show metrics like RAM/CPU/SPACE etc? It’s a Cisco SG300 Switch.
Browser: Firefox 130.0
Agent: netdata v1.47.1
buildinfo of that agent:
Packaging:
    Netdata Version ____________________________________________ : v1.47.1
    Package Distro _____________________________________________ : debian 12
    Configure Options __________________________________________ : dummy-configure-command
Default Directories:
Operating System:
    Kernel Version _____________________________________________ : 6.8.8-4-pve
    Operating System ___________________________________________ : unknown
    Operating System ID ________________________________________ : unknown
    Operating System ID Like ___________________________________ : unknown
    Operating System Version ___________________________________ : unknown
    Operating System Version ID ________________________________ : 12
    Detection __________________________________________________ : unknown
Hardware:
    CPU Cores __________________________________________________ : 2
    CPU Frequency ______________________________________________ : 2800000000
    RAM Bytes __________________________________________________ : 4294967296
    Disk Capacity ______________________________________________ : 256060514304
    CPU Architecture ___________________________________________ : x86_64
    Virtualization Technology __________________________________ : none
Container:
    Container __________________________________________________ : lxc
    Container Operating System _________________________________ : Debian GNU/Linux
    Container Operating System ID ______________________________ : debian
    Container Operating System ID Like _________________________ : unknown
    Container Operating System Version _________________________ : 12 (bookworm)
    Container Operating System Version ID ______________________ : 12
    Container Operating System Detection _______________________ : /etc/os-release
Features:
Database Engines:
    dbengine (compression) _____________________________________ : YES (zstd lz4)
Connectivity Capabilities:
Libraries:
    libmnl (library for working with netfilter) ________________ : YES
Plugins:
    Xen ________________________________________________________ : YES
Exporters:
Debug/Developer Features:
I expect it to create a vNode like that SMTP device would be a real node.
Hi, this is not available in v1.47.1, only in the nightly version.
Oh I see, is there any release date yet for when it comes to stable.
And any ideas how I could get more metrics, like cpu/ram/disk/fan etc? Currently there is like only network flow in different types and port status of my switch.
No, there is no release date.
No.
