Hello, I’m new to Netdata, I want to ask if there is a way to display a graph of CPU usage history? I see one here, but it shows the load split. I would like the total CPU load like it is in that main circular indicator above, but in the form of a graph. Is this possible to achieve? Thank you very much!
Hi, @Fany. Change “Group by” to "node.
Thank you! I’ve tried so many clicking combinations with no success. And it was so easy.
Thank you very much. I got exactly the chart I want.
