When using NETDATA Cloud, where are data stored - is that local on each node/agent DB or on your Cloud product? Can we “pick” a different storage?
If only on the end node, does this therefore mean that with a node “down”, we’re not able to see its data?
Separately, is there a maximum retention period (either in-node or Cloud)? I see 30d at the top (which is fiddly and sometimes crashes the browser window when changed…), but is longer analysis possible?
For example, we often compare with last year’s data (for a server that holds one of our e-commerce platforms).
