We’ve noticed that some agents on the VMs we monitor with netdata seem to reload without any real indication as to why they are doing so.
On what seems like a side note, when the agents reload, there is a small bug in the netdata service file in regards to the issue found here: Fix boolean value for ProtectControlGroups by didier13150 · Pull Request #11281 · netdata/netdata · GitHub
The issue is due to the fact that ProtectControlGroups expects ‘on’ or ‘yes’ but is configured with ‘true’. Not a problem since we can manually update the netdata.service file. OK.
My question is, when reviewing the Journal logs, we see that the netdata agent is reloading without any prior reason. We don’t see this type of behavior on many of the other nodes that we monitor. We are curious to understand why they reload and what triggers the reload?
Our sample Journal log is below.
Thanks in advance!
[root@netdata-snmp-agent ~]# journalctl --since "2022-07-25 03:45" --until "2022-07-25 03:55"
-- Logs begin at Thu 2022-07-14 21:04:17 UTC, end at Mon 2022-07-25 13:55:13 UTC. --
Jul 25 03:50:53 netdata-snmp-agent systemd[1]: Reloading.
Jul 25 03:50:53 netdata-snmp-agent systemd[1]: [/usr/lib/systemd/system/netdata.service:50] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Jul 25 03:50:53 netdata-snmp-agent systemd[1]: [/usr/lib/systemd/system/netdata.service:69] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Jul 25 03:50:53 netdata-snmp-agent systemd[1]: Stopping Real time performance monitoring...
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: Stopped Real time performance monitoring.
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: Starting Real time performance monitoring...
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: Started Real time performance monitoring.
Jul 25 03:50:56 netdata-snmp-agent yum[8462]: Updated: netdata-1.35.0.211.nightly-1.el7.x86_64
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: Reloading.
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: [/usr/lib/systemd/system/netdata.service:50] Failed to parse capability in bounding/ambient set, ignoring: CAP_PERFMON
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: [/usr/lib/systemd/system/netdata.service:69] Unknown lvalue 'ProtectControlGroups' in section 'Service'
Jul 25 03:50:56 netdata-snmp-agent systemd[1]: Stopping Real time performance monitoring...
Jul 25 03:50:58 netdata-snmp-agent ebpf.plugin[8698]: Does not have a configuration file inside `/etc/netdata/ebpf.d.conf. It will try to load stock file.
Jul 25 03:50:58 netdata-snmp-agent ebpf.plugin[8698]: Name resolution is disabled, collector will not parser "hostnames" list.
Jul 25 03:50:58 netdata-snmp-agent ebpf.plugin[8698]: The network value of CIDR 127.0.0.1/8 was updated for 127.0.0.0 .
Jul 25 03:50:58 netdata-snmp-agent ebpf.plugin[8698]: Cannot read process groups configuration file '/etc/netdata/apps_groups.conf'. Will try '/usr/lib/netdata/conf.d/apps_groups.conf'
Jul 25 03:50:58 netdata-snmp-agent ebpf.plugin[8698]: ebpf.plugin should either run as root (now running with uid 997, euid 997) or have special capabilities..
Jul 25 03:51:04 netdata-snmp-agent systemd[1]: Stopped Real time performance monitoring.
Jul 25 03:51:04 netdata-snmp-agent systemd[1]: Starting Real time performance monitoring...
Jul 25 03:51:04 netdata-snmp-agent systemd[1]: Started Real time performance monitoring.
Jul 25 03:51:05 netdata-snmp-agent run-parts(/etc/cron.daily)[9059]: finished netdata-updater
Jul 25 03:51:05 netdata-snmp-agent anacron[7905]: Job `cron.daily` terminated
Jul 25 03:51:05 netdata-snmp-agent anacron[7905]: Normal exit (1 job run)
Jul 25 03:51:05 netdata-snmp-agent systemd[1]: Removed slice User Slice of root.
Jul 25 03:51:06 netdata-snmp-agent ebpf.plugin[9103]: Does not have a configuration file inside `/etc/netdata/ebpf.d.conf. It will try to load stock file.
Jul 25 03:51:06 netdata-snmp-agent ebpf.plugin[9103]: Name resolution is disabled, collector will not parser "hostnames" list.
Jul 25 03:51:06 netdata-snmp-agent ebpf.plugin[9103]: The network value of CIDR 127.0.0.1/8 was updated for 127.0.0.0 .
Jul 25 03:51:07 netdata-snmp-agent ebpf.plugin[9103]: Cannot read process groups configuration file '/etc/netdata/apps_groups.conf'. Will try '/usr/lib/netdata/conf.d/apps_groups.conf'
Jul 25 03:51:07 netdata-snmp-agent ebpf.plugin[9103]: ebpf.plugin should either run as root (now running with uid 997, euid 997) or have special capabilities..
