Will custom dashboards and API v1 be discontinued?
Suggested template:
v1.45.5
Availability of API v1 charts
Ever since I found Netdata I’ve used the API v1 to create my own dashboards in an angular platform, however it’s come to my attention that on the swagger the /api/v1/charts is stated as EOL, and the description prompts to use contexts instead, will this have a similar behavior? or with the EOL of /api/v1/chart comes the EOL of API v1 itself as well? Is there in the roadmap to keep v1 support of will v2 offer the chance to create dashboards using the HTML way described in Dashboards Tab | Learn Netdata.
Or not at all and the strategy is to offer custom dashboards only through the netdata cloud env?
