10min disk backlog does not update
I get a warning about 10min disk backlog, when i open the warning it says:
Check
Check every:
60 seconds
But the last update is 20 hours ago… The node is live and checked if the service is running. Everything else works as it should.
Any tips?
With kind regards,
Buck Baggen
Sorry, service was indeed running, but after a sudo systemctl restart netdata it wont start anymore. Runned the kickstart script for a repair/reinstall and now it works (and the 10min disk backlog warnings refreshed and disappeared :slight_smile:
