So im rather now to all this and I recently installed netdata using the installer script which all seemed to work fine, I have opened the port 19999 with ufw, and if I curl the localhost:19999 it spams all the HTML (im assuming this is the panel) but when i access it in my browser with ip and port 19999 I just get nothing. It says it is listening on every ip so I dont see why it wont connect, i found a GitHub issue (#1203) like this but i followed stuff there and nothing worked. Any help would be great thanks. Im rather new to this so some explanation would be greatly appreciated.
I disabled the firewall and i am now able to access it, This is odd as i already have other applications such as Pterodactyl running on the machine fine. Im going to try specifying more details with the ufw rule rather than an more general rule, ill let you know how that goes.
I setup some more specific ufw rules, specifying the protocol, origin ip and a few other things (which should have all been default) and its working now, just seems it was ufw being odd. Thanks for the help anyway, all solved now.
