Hello!
Im new with netdata and want to add a snmp UPS.
I can reach the UPS with snmpwalk and have the UPS aleready added into a nagios.
I have tried to edit the switch example in the snmp conf, but i seem to make an mistake somewhere, because nothing appears in the webgui after i restartet the netdata service.
Config(bit messy):
And ckecking the logs:
If the read.go:71 means line 71 its the marked, commented out line in the config.
Is it possible to “translate” every oid types?
There are for example batterystatus which are numbers from 1 to 4 whch are in nagios translated via certain files distributed by the manufacturer.
Thank you for your help again!
