I’ve been using the SNMP collector against a couple of switches but haven’t been able to get the OID for system uptime to work.
snmpwalk works fine:
snmpwalk -t 20 -O fn -v 2c -c netdata 192.168.178.3 .1.3.6.1.2.1.1.3
returns:
.1.3.6.1.2.1.1.3.0 = Timeticks: (6365400) 17:40:54.00
but the graphs say ‘no data’ ands running the module in debug mode returns:
[ DEBUG ] snmp[GS110TPP_switch] collect.go:49 skipping OID ‘1.3.6.1.2.1.1.3’ (unsupported type ‘NoSuchInstance’)
and then:
BEGIN ‘snmp_GS110TPP_switch.snmp_switch.management.uptime’
SET ‘Switch Uptime’ =
END
My snmp.conf has two jobs, one for each switch. And the config for one looks like this:
- name: GS110TPP switch
update_every: 5
hostname: “192.168.178.3”
community: netdata
options:
version: 2
charts:
- id: “snmp_switch.bandwidth_port.GS110TPP”
title: “GS110TPP Switch Bandwidth for port”
units: “MiB/s”
type: “area”
family: “ports”
multiply_range: [1, 10]
dimensions:
- name: “in”
oid: “1.3.6.1.2.1.2.2.1.10.”
algorithm: “incremental”
multiplier: 8
divisor: 1000000- name: “out”
oid: “1.3.6.1.2.1.2.2.1.16.”
multiplier: 8
divisor: 1000000- id: “snmp_switch.management.uptime.GS110TPP”
title: “GS110TPP Switch Uptime”
units: “percent”
type: “line”
family: “switch_management”
dimensions:
- name: “Switch Uptime”
oid: “1.3.6.1.2.1.1.3”
algorithm: “absolute”
The port bandwidth counters work fine AFAIK, so I’m not sure what I’m doing wrong with the uptime one as I believe the collector should handle TIMETICKS.
