Environment
Centos7 - installed via EPEL
Arch : x86_64
Version : 1.31.0
Release : 1.el7
First of all, just wanted to say I love Netdata and have found the addition of Netdata cloud to be amazing for my use case.
I have a heterogeneous collection of clients’ servers, mostly LAMP but some other stacks, that I’m monitoring with Netdata cloud.
These are client’s individual servers that they’ve given me access to in order to maintain and monitor, so I have decided to go with RPM/DEB installations so as to get Netdata installed as cleanly as possible - for this scenario, it’s far preferable to the netdata-installer from my POV - e.g. if they ever cease to be my clients, it will be very easy to remove Netdata if necessary, though I would strongly suggest the next guy or girl use it also ![]()
The issue is: I’m getting automatic email notifications (no setup/config needed) via Netdata Cloud for some of these machines, but not others. I should mention that the most recent batch of machines (which don’t seem to be alerting) has had Netdata installed via the EPEL repo for Centos7, whereas the older ones (which do seem to be alerting) were installed via the packagecloud repo. EPEL seemed to have an up-to-date version, so I went with that rather than add yet another YUM repo to the boxes.
What I have noticed, is that the EPEL version seems to have the many alert config files in /etc/netdata/conf.d/health.d, whereas the packagecloud version seems to have these config files in /usr/lib/netdata/conf.d/health.d/
I have had a situation recently where the CPU was pinned at 100% for hours on end, causing issues with a client’s live site, yet I received no alerts
There were no problems connecting these EPEL Netdata instances to Netdata Cloud
I would expect these automatically configured alerts to fire via Netdata Cloud if there was an issue (as there has been recently). If more config is needed, or if I should switch to the packagecloud repo, I’m happy to do that, but I’m keen to know what the root cause might be, even if only to file a bug with the EPEL maintainer in order to improve the package if there’s a bug (and be a good open source citizen
Many Thanks in advance
