I am Can not remove War Rooms. When we do remove button but War Rooms still are not removed.
Hi @Nirjonadda ,
Thank you for reaching out to us! We’ve been trying to reproduce this problem and think we have managed to do so. This problem does not seem to happen for all room deletions.
Could you please open the development tools, set “rooms” as a filter in the network capture and provide us with the error returned there? There should be a request that shows up red. If this is the same issue you should be able to see an “ErrForbiddenNotRoomMember” error there if this is the same issue.
Kind regards,
Christos
Hi @Nirjonadda ,
Thank you very much for your response! I’ll take a look in our backend and see if I can fix this for you.
Kind regards,
Christos
