I had to reinstall Ubuntu (24.04.4 LTS aarch64) on my four cluster nodes. When trying to restart Netdata in a Docker (29.5.2) container /* I used the example command from your website */, I came to the point where the Netdata dashboards of all four nodes worked. What did not work, though, was claiming them in the cloud dashboard. I used the corresponding token I read from:
docker exec netdata cat /var/lib/netdata/netdata_random_session_id
Alas, on all four nodes, I got this error message:
Request failed with error: SSL connect error
proxy: 'env',
insecure: false,
public key file: '/var/lib/netdata/cloud.d/public.pem',
trusted key file: 'none'
Yes, I do have a firewall with HTTP/HTTPS proxy sitting between the nodes and the rest of my network, but is this the cause why the SSL connection breaks? Or does it have to do with the non-standard TCP ports (19995 thru 19998, one for each node) I have to use because of the firewall? Last time, the claim worked flawlessly!
I also executed this command, but no use:
sudo apt-get install --reinstall ca-certificates
Yes, your proxy is almost certainly the cause.
The proxy: 'env' in the error means Netdata is looking for proxy settings in environment variables but either they’re not set inside the container, or the proxy is intercepting the SSL connection and presenting its own certificate which Netdata rejects.
The cleanest fix for Docker is to pass the proxy when starting the container using the NETDATA_CLAIM_PROXY environment variable:
docker run -d \
--name netdata \
-e NETDATA_CLAIM_TOKEN=YOUR_TOKEN \
-e NETDATA_CLAIM_ROOMS=YOUR_ROOM_IDS \
-e NETDATA_CLAIM_PROXY=http://your-proxy-host:your-proxy-port \
... (rest of your existing flags)
netdata/netdata
Alternatively, claim manually from inside the container:
docker exec netdata netdata-claim.sh \
-token=YOUR_TOKEN \
-rooms=YOUR_ROOM_IDS \
-url=https://app.netdata.cloud \
-proxy=http://your-proxy-host:your-proxy-port
First, verify the proxy can reach Netdata Cloud from inside the container:
docker exec netdata curl -v --proxy http://your-proxy-host:port https://app.netdata.cloud
If that fails, the proxy is blocking or intercepting the connection. Make sure it allows outbound connections to app.netdata.cloud:443 and mqtt.netdata.cloud:443.
The non-standard ports (19995-19998) won’t affect claiming.
The claim from inside the container seems not to work:
mixtile@blade3n4:~$ docker exec netdata netdata-claim.sh \
-token=8b2aeee5-5736-49f9-8f7b-ac712c995a1a \
-rooms=jacek-ruzyczka \
-proxy=http://10.20.0.1:3128
OCI runtime exec failed: exec failed: unable to start container process: exec: "netdata-claim.sh": executable file not found in $PATH
Neither does recreating the container work:
mixtile@blade3n4:~$ docker run -d --name netdata -e NETDATA_CLAIM_TOKEN=8b2aeee5-5736-49f9-8f7b-ac712c995a1a -e NETDATA_CLAIM_ROOMS=clusterbox -e NETDATA_CLAIM_PROXY=http://10.20.0.1:3128 netdata/netdata
4bba5467933b308abbaeddeec55fa9d750920fa71cea18143944c8809b42a09c
This is all I get when using the browser to load the dashboard:
Failed to fetch
For the “Failed to fetch”, your docker run command is missing port mapping.
Add -p 19995:19999 (or whichever port you’re using) so the dashboard is accessible from outside the container.
netdata-claim.sh not found appears because this script is deprecated in current Docker images.
Claiming is now handled by the daemon itself via environment variables or claim.conf.
SSL connect error appears because your proxy at 10.20.0.1:3128 is almost certainly doing SSL interception, which Netdata rejects.
The fix is to create a claim.conf file with insecure = yes to accept the proxy’s certificate:
url = https://app.netdata.cloud
token = YOUR_TOKEN
rooms = YOUR_ROOM_ID
proxy = http://10.20.0.1:3128
insecure = yes
Mount it into the container:
docker run -d --name=netdata \
--pid=host \
-p 19995:19999 \
-v /path/to/claim.conf:/etc/netdata/claim.conf:ro \
-v netdataconfig:/etc/netdata \
-v netdatalib:/var/lib/netdata \
-v netdatacache:/var/cache/netdata \
-v /:/host/root:ro,rslave \
-v /etc/passwd:/host/etc/passwd:ro \
-v /etc/group:/host/etc/group:ro \
-v /proc:/host/proc:ro \
-v /sys:/host/sys:ro \
-v /etc/os-release:/host/etc/os-release:ro \
--restart unless-stopped \
--cap-add SYS_PTRACE \
--cap-add SYS_ADMIN \
--security-opt apparmor=unconfined \
netdata/netdata
The non-standard dashboard ports don’t affect claiming, as that’s outbound on 443 only.
And the room name, which is one of the arguments, is not the same as the space name (= my own name)?
BTW, I can’t add a `netdata.conf` because it’s a directory inside the container:
mixtile@blade3n4:~$ docker run -d --name=netdata --pid=host -p 19995:19999 -v /etc/netdata/claim.conf:/etc/netdata/claim.conf:ro -v netdataconfig:/etc/netdata -v netdatalib:/var/lib/netdata -v netdatacache:/var/cache/netdata -v /:/host/root:ro,rslave -v /etc/passwd:/host/etc/passwd:ro -v /etc/group:/host/etc/group:ro -v /proc:/host/proc:ro -v /sys:/host/sys:ro -v /etc/os-release:/host/etc/os-release:ro --restart unless-stopped --cap-add SYS_PTRACE --cap-add SYS_ADMIN --security-opt apparmor=unconfined netdata/netdata
91f3d596c72eac3e9edd53cd0b79342011b67a00c3a20c2c6343d84f73a5a582
docker: Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/etc/netdata/claim.conf" to rootfs at "/etc/netdata/claim.conf": mount src=/etc/netdata/claim.conf, dst=/etc/netdata/claim.conf, dstFd=/proc/thread-self/fd/11, flags=MS_BIND|MS_REC: not a directory: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type
On the room ID question: the -rooms argument takes the room’s UUID, not its display name. You can find it in the URL when you navigate to a room in Netdata Cloud. If you leave it out entirely, the node will land in the General room by default.
On the mount error: the problem is that /etc/netdata/claim.conf doesn’t exist on the host yet, so Docker has nothing to bind. You need to create the file first:
mkdir -p /etc/netdata
cat > /etc/netdata/claim.conf << 'EOF'
token = YOUR_TOKEN
rooms = YOUR_ROOM_UUID
insecure = yes
EOF
Once the file exists on the host, the mount in your docker run command will work correctly.
One thing to be aware of: insecure = yes helps with the initial claiming step, but the ongoing connection to Cloud uses a separate library that doesn’t support SSL interception. If claiming succeeds but the node shows as offline, your proxy may be the blocker for the persistent connection as well. In that case the cleanest solution is to have your proxy whitelist app.netdata.cloud and mqtt.netdata.cloud on port 443 without intercepting the traffic.
When I navigate to my room clusterbox, I’ve got this URL in the browser and can’t figure out which of the strings are the UUID:
https://app.netdata.cloud/spaces/jacek-ruzyczka-space/rooms/all-nodes/onboarding#metrics_correlation=false&after=-900&before=0&modal=&modalTab=&_o=rZLBasMwDIbfxecK7NiJ7b7AGIz10LJrkWJ5zWjjkqTdoPTd57SBDcagHbvJEr_0_bJOok2BH8MqPSQ44lbMxY7bw3oR47Zped0f6PJ2aBSjrYCiMmB8IcGzN1CURtbSKq2CFDPRc3fkroch1UvGrt5MPb-VxnnLAYdDD_yxxzZwgERvYn4S01AxH7oDz8RTc5zi80zUZXDBUgFlYTNApQlIVR6kqQKijDUWHhRra2NgKEsiMEoVQNo4UC4zMkYvs4PUUsIuNO0rbNKOYd1nGoaeh2HMXYG1dqS8iqC8V2C08YBWZr9VhT6QdgWVo6kmMGG32HMLlFJWXtGn_App6odb7ob-S_F82fpUrApSLtYlaI8IhlmCoypb1SpaE2105LP0JnfwE0mMTLfqx-_pXxp-v0T_dhh3zv59f39rdP-6z58
BTW, the proxy configuration was slightly more complicated than expected: I had to add some ssl_bump rules, too. Unfortunately, the file error still persists when applying the command you sent me, probably because claim.conf is still a directory in the docker image:
Error response from daemon: failed to create task for container: failed to create shim task: OCI runtime create failed: runc create failed: unable to start container process: error during container init: error mounting "/etc/netdata/claim.conf" to rootfs at "/etc/netdata/claim.conf": mount src=/etc/netdata/claim.conf, dst=/etc/netdata/claim.conf, dstFd=/proc/thread-self/fd/14, flags=MS_BIND|MS_REC: not a directory: Are you trying to mount a directory onto a file (or vice-versa)? Check if the specified host path exists and is the expected type.
The env variable approach from the first reply is probably your best shot here — the netdata-claim.sh path is a dead end since it’s deprecated. Did you try passing NETDATA_CLAIM_PROXY when you spun up the container, or did you only attempt it with docker exec? The proxy certs are definitely the culprit (SSL interception), but you gotta feed it at container start time, not after.
