Clear linux.. (is this the problem?)
total netdata newbie… I’ve used it before but never had to administrate anything… everything just worked…
So Clear linux has a netdata bundle… but it doesn’t seem to start (I’ve added to an existing pr someone had) and managed to figure out how to get netdata working… but I cannot restart, or edit, or touch anything… it will never restart…
So I removed the bundle and rm’d the created directories… and tried the one-liner… which was initially better.
But in trying to switch to dbengine in /opt/netdata/etc/netdata/netdata.conf it would also never stop, restart, or start again…
I ran the uninstall script after fighting… had to pass the path to the .env file… and the uninstall seemed to clean everything up…
So I rebooted the machine and tried again… with the one-liner… same “cannot edit anything” and “only starts the first time”…
I’ve removed via the uninstall script…
How/where should I start?
Thanks in advance.
