Debian 10 apt-get upgrade fails with nightly netdata-edge.list
Fresh and first installation with wget script provided, now getting emails every night because of this error.
Is this normal for Nightly builds, should i change to stable to get rid of these errors ? :
root@web4:~# apt-get update
root@web4:~# apt-get upgrade
Reading package lists… Done
Building dependency tree
Reading state information… Done
Calculating upgrade… Done
The following packages have been kept back:
libapache2-mod-php netdata-plugin-ebpf php-apcu php-curl php-imagick php-mbstring php-memcache php-mysql php-xml php7.4-imagick php8.0-apcu php8.0-imagick php8.0-memcache php8.1-apcu php8.1-imagick php8.1-memcache
The following packages will be upgraded:
netdata netdata-plugin-apps netdata-plugin-chartsd netdata-plugin-debugfs netdata-plugin-go netdata-plugin-nfacct netdata-plugin-perf netdata-plugin-pythond netdata-plugin-slabinfo
9 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
27 not fully installed or removed.
Need to get 0 B/23.9 MB of archives.
After this operation, 89.1 kB of additional disk space will be used.
Do you want to continue? [Y/n]
Reading changelogs… Done
dpkg: regarding …/0-netdata_1.39.0-116-nightly_amd64.deb containing netdata:
netdata conflicts with netdata-base
netdata-base (version 1.39.0-108-nightly) is present and installed.
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/0-netdata_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata
dpkg: regarding …/1-netdata-plugin-apps_1.39.0-116-nightly_amd64.deb containing netdata-plugin-apps:
netdata-plugin-apps conflicts with netdata (<< 1.39.0-116-nightly)
netdata (version 1.39.0-108-nightly) is present and installed.
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/1-netdata-plugin-apps_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-apps
dpkg: regarding …/2-netdata-plugin-pythond_1.39.0-116-nightly_all.deb containing netdata-plugin-pythond:
netdata-plugin-pythond conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/2-netdata-plugin-pythond_1.39.0-116-nightly_all.deb (–unpack):
conflicting packages - not installing netdata-plugin-pythond
dpkg: regarding …/3-netdata-plugin-go_1.39.0-116-nightly_amd64.deb containing netdata-plugin-go:
netdata-plugin-go conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/3-netdata-plugin-go_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-go
dpkg: regarding …/4-netdata-plugin-debugfs_1.39.0-116-nightly_amd64.deb containing netdata-plugin-debugfs:
netdata-plugin-debugfs conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/4-netdata-plugin-debugfs_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-debugfs
dpkg: regarding …/5-netdata-plugin-nfacct_1.39.0-116-nightly_amd64.deb containing netdata-plugin-nfacct:
netdata-plugin-nfacct conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/5-netdata-plugin-nfacct_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-nfacct
dpkg: regarding …/6-netdata-plugin-chartsd_1.39.0-116-nightly_all.deb containing netdata-plugin-chartsd:
netdata-plugin-chartsd conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/6-netdata-plugin-chartsd_1.39.0-116-nightly_all.deb (–unpack):
conflicting packages - not installing netdata-plugin-chartsd
dpkg: regarding …/7-netdata-plugin-slabinfo_1.39.0-116-nightly_amd64.deb containing netdata-plugin-slabinfo:
netdata-plugin-slabinfo conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/7-netdata-plugin-slabinfo_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-slabinfo
dpkg: regarding …/8-netdata-plugin-perf_1.39.0-116-nightly_amd64.deb containing netdata-plugin-perf:
netdata-plugin-perf conflicts with netdata (<< 1.39.0-116-nightly)
dpkg: error processing archive /tmp/apt-dpkg-install-UrPxL6/8-netdata-plugin-perf_1.39.0-116-nightly_amd64.deb (–unpack):
conflicting packages - not installing netdata-plugin-perf
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
root@web4:~#
Suggested template:
Ho, @kimmo. The same issue is on GitHub. The fix is merged today. Should be fixed in today’s nightly release.
