Disable local monitoring?
Can i disable local host monitoring and just have the server running to show remote netdata hosts?
Of course, you just disable any data collection plugin you don’t want, in netdata.conf
Basically uncomment what you see below and put a no instead of the yes.
[plugins]
# timex = yes
# idlejitter = yes
# netdata monitoring = yes
# tc = yes
# diskspace = yes
# proc = yes
# cgroups = yes
# statsd = yes
# enable running new plugins = yes
# slabinfo = no
# python.d = yes
# perf = yes
# ioping = yes
# nfacct = yes
# go.d = yes
# apps = yes
# ebpf = yes
# charts.d = yes
Thank you,
one more
[ml]
enable = no
and the screen is completly empty.
