vlvkobal:
chart_variables
“chart”: “apps.uptime”,
“chart_name”: “apps.uptime”,
“chart_context”: “apps.uptime”,
“chart_variables”: {
“X”: 109589.00000,
“cron_raw”: 10746.00000,
“NX_Witness_last_collected_t”: 1622122413.00000,
“charts.d.plugin_last_collected_t”: 1622122413.00000,
“NX_Witness_raw”: 5105.00000,
“kernel_last_collected_t”: 1622122413.00000,
“nms_raw”: 197052.00000,
“python.d.plugin_last_collected_t”: 1622122137.00000,
“ssh_last_collected_t”: 1622122413.00000,
“nfs”: 197097.00000,
“nms”: 197052.00000,
“dhcp_raw”: 197061.00000,
“ssh”: 83329.00000,
“cron_last_collected_t”: 1622122413.00000,
“red”: null,
“X_raw”: 109589.00000,
“X_last_collected_t”: 1622122413.00000,
“kernel”: 197097.00000,
“tc_qos_helper”: 278.00000,
“apps.plugin_last_collected_t”: 1622122413.00000,
“netdata_raw”: 280.00000,
“nms_last_collected_t”: 1622122413.00000,
“nfs_last_collected_t”: 1622122413.00000,
“nfs_raw”: 197097.00000,
“dhcp”: 197061.00000,
“go.d.plugin_last_collected_t”: 1622122413.00000,
“netdata”: 280.00000,
“charts.d.plugin”: 278.00000,
“update_every”: 1.00000,
“go.d.plugin”: 278.00000,
“check_if_NX_Witness_is_running”: null,
“node.d.plugin_last_collected_t”: 1622122138.00000,
“system_last_collected_t”: 1622122413.00000,
“other”: 197097.00000,
“apps.plugin”: 278.00000,
“apps.plugin_raw”: 278.00000,
“dhcp_last_collected_t”: 1622122413.00000,
“netdata_last_collected_t”: 1622122413.00000,
“ssh_raw”: 83329.00000,
“go.d.plugin_raw”: 278.00000,
“other_raw”: 197097.00000,
“tc_qos_helper_last_collected_t”: 1622122413.00000,
“system_raw”: 197068.00000,
“node.d.plugin”: null,
“python.d.plugin_raw”: 2.00000,
“NX_Witness”: 5105.00000,
“other_last_collected_t”: 1622122413.00000,
“kernel_raw”: 197097.00000,
“node.d.plugin_raw”: 3.00000,
“python.d.plugin”: null,
“last_collected_t”: 1622122413.00000,
“system”: 197068.00000,
“charts.d.plugin_raw”: 278.00000,
“green”: null,
“collected_total_raw”: 1392633.00000,
“tc_qos_helper_raw”: 278.00000,
“cron”: 10746.00000
