Hi everyone,
Quick question. How can we troubleshoot slow chart loads / performance issues in the WebUI? For instance, quite often when the webUI loads it will either take a while for the page to initially render or if we scroll to a specific chart down the page that chart takes a while to render.
Here’s a screenshot of the developer tools:
If I do the comparable cURL command with timing enabled:
time curl 'http://vault-dbsa102:19999/api/v1/data?chart=vault.fetch_times&_=1638542499749&format=json&points=382&group=average>ime=0&options=ms%7Cflip%7Cjsonwrap%7Cnonzero&after=-420' \
-H 'Connection: keep-alive' \
-H 'Pragma: no-cache' \
-H 'Accept: application/json, text/plain, */*' \
-H 'Cache-Control: no-cache, no-store' \
-H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36' \
-H 'Sec-GPC: 1' \
-H 'Referer: http://vault-dbsa102:19999/' \
-H 'Accept-Language: en-US,en;q=0.9' \
-H 'Cookie: ph_mqkwGT0JNFqO-zX2t0mW6Tec9yooaVu7xCBlXtHnt5Y_posthog=%7B%22distinct_id%22%3A%2217d480d8ba9930-074bb2e7cc14f4-1e396452-1fa400-17d480d8baaaa9%22%2C%22%24device_id%22%3A%2217d480d8ba9930-074bb2e7cc14f4-1e396452-1fa400-17d480d8baaaa9%22%7D' \
--compressed
I see that it takes 16 seconds
0.01s user 0.01s system 0% cpu 16.031 total
Here’s the global/web config
$ curl -s http://localhost:19999/netdata.conf
# netdata configuration
# You can download the latest version of this file, using:
# wget -O /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
# or
# curl -o /etc/netdata/netdata.conf http://localhost:19999/netdata.conf
# You can uncomment and change any of the options below.
# The value shown in the commented settings, is the default value.
# global netdata configuration
config directory = /etc/netdata/conf.d
history = 43932
page cache size = 64
dbengine multihost disk space = 512
memory mode = save
errors to trigger flood protection = 1000
update every = 5
# run as user = netdata
# glibc malloc arena max for plugins = 1
# glibc malloc arena max for netdata = 1
# hostname = vault-dbsa102.prod.ostk.com
# stock config directory = /usr/lib64/netdata/conf.d
# log directory = /var/log/netdata
# web files directory = /usr/share/netdata/web
# cache directory = /var/cache/netdata
# lib directory = /var/lib/netdata
# home directory = /var/log/netdata
# lock directory = /var/lib/netdata/lock
# plugins directory = "/usr/libexec/netdata/plugins.d" "/etc/netdata/custom-plugins.d"
# dbengine disk space = 256
# host access prefix =
# memory deduplication (ksm) = yes
# TZ environment variable = :/etc/localtime
# timezone = America/Denver
# debug flags = 0x0000000000000000
# debug log = /var/log/netdata/debug.log
# error log = /var/log/netdata/error.log
# access log = /var/log/netdata/access.log
# facility log = daemon
# errors flood protection period = 1200
# OOM score = 1000
# process scheduling policy = idle
# pthread stack size = 8388608
# cleanup obsolete charts after seconds = 3600
# cleanup orphan hosts after seconds = 3600
# delete obsolete charts files = yes
# delete orphan hosts files = yes
# enable zero metrics = no
# dbengine extent pages = 64
[web]
web files owner = netdata
web files group = netdata
bind to = 0.0.0.0
allow management from = localhost dbaautomation*
# ssl key = /etc/netdata/conf.d/ssl/key.pem
# ssl certificate = /etc/netdata/conf.d/ssl/cert.pem
# tls version = 1.3
# tls ciphers = none
# ses max window = 15
# des max window = 15
# mode = static-threaded
# listen backlog = 4096
# default port = 19999
# disconnect idle clients after seconds = 60
# timeout for first request = 60
# accept a streaming request every seconds = 0
# respect do not track policy = no
# x-frame-options response header =
# allow connections from = localhost *
# allow connections by dns = heuristic
# allow dashboard from = localhost *
# allow dashboard by dns = heuristic
# allow badges from = *
# allow badges by dns = heuristic
# allow streaming from = *
# allow streaming by dns = heuristic
# allow netdata.conf from = localhost fd* 10.* 192.168.* 172.16.* 172.17.* 172.18.* 172.19.* 172.20.* 172.21.* 172.22.* 172.23.* 172.24.* 172.25.* 172.26.* 172.27.* 172.28.* 172.29.* 172.30.* 172.31.* UNKNOWN
# allow netdata.conf by dns = no
# allow management by dns = heuristic
# enable gzip compression = yes
# gzip compression strategy = default
# gzip compression level = 3
# web server threads = 1
# web server max sockets = 256
# custom dashboard_info.js =
Netdata version
netdata -v
netdata v1.31.0
