Suggested template:
cmd:
- ~/kickstart.sh
- –dont-wait
- –disable-cloud
- –disable-telemetry
- –no-updates
delta: ‘0:00:35.743456’
end: ‘2025-08-21 09:29:58.076957’
msg: non-zero return code
rc: 1
start: ‘2025-08-21 09:29:22.333501’
The following packages have unmet dependencies:
netdata : Depends: netdata-dashboard but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Thu Aug 21 09:30:03 UTC 2025 : FATAL: netdata-updater.sh: FAILED TO UPDATE NETDATA: Failed to update Netdata package.
FAILED
smooth upgrade
