I have a streaming netdata setup with 1 parent and 3 child nodes. One of the nodes’ (named phoenix below)system.cpu data is missing from Netdata cloud.
At this moment we see that the system.cpuchart at phoenix is collected properly, so data should be returned to the browser. Could you try again in order to discard it was a temporary issue?
Hey @Juan - thanks for taking a look. It seems like there’s some replication lag/delay which affects some metrics depending on when I observe the dashboard. For example, right now I see the system.load and system.net graphs missing data for last about 5 hours for this node.
A couple of questions: The children are not claimed themselves, right? Only the parent is?
Could you check the phoenix’s local dashboard through the parent? I.e. open parent’s local dashboard, then click on phoenix and check if the metrics missing from the cloud appear there? I know you did so in point 4, but not sure if you checked the child’s dashboard or through the parent. This check should rule out or not streaming issues from child to parent.
Following up on this, have been checking up on the graphs for a few times and it seems like the issue is fixed. Reducing the collection rate to every 5 seconds seems to have helped avoid the replication lag/missing data here. Thanks @Juan@Manolis_Vasilakis for taking a look!
