Hi:
I am working on a custom netdata module written in python. By default, python.d seems to use the system python install, but my module requires packages that I don’t want to install globally. So, I want python.d to use a virtual environment (virtualenv). I can get python.d to see the virtualenv python binary by adding the following to /etc/netdata/netdata.conf:
[plugin:python.d]
command options = -p/home/[username]/envs/netdata/bin/python3
Where /home/[username]/envs/netdata/bin/python3 is in my home directory and is the location of the python3 binary for the “netdata” virtualenv.
This “works” in that the log files shows that python.d attempts to use the virtualenv python binary. But, when restarting netdata, I get a permissions error that the binary cannot be executed by python.d:
/usr/libexec/netdata/plugins.d/python.d.plugin: line 18: /home/[username]/envs/netdata/bin/python3: Permission denied
/usr/libexec/netdata/plugins.d/python.d.plugin: line 18: exec: /home/[username]/envs/netdata/bin/python3: cannot execute: Permission denied
I have tried successively more liberal permission/ownership settings, and none have worked. Here are the current permissions for the python3 binary in question:
-rwxrwxrwx. 1 netdata netdata 11328 Sep 12 05:20 python3
The containing “netdata” and “bin” directories have the same reckless permission settings.
On top of these settings, I have also tried temporarily setting SELinux enforcement to “Permissive”, and that has no effect. I don’t see any entries in /var/log/audit/audit.log that would suggest SELinux is blocking anything, but I confess I generally find SELinux baffling and could be missing something.
Question: What I am doing wrong here, and what permission settings (or other measures) can I take to allow python.d to use this python virtualenv?
Operating System: CentOS Linux 7 (Core)
Kernel: Linux 3.10.0-1160.76.1.el7.x86_64
Netdata v1.36.0-104-nightly
Thanks,
David Rose
