removing stale node
Hi, so my cloud instance seems to have a stale node that I can’t delete. Trash icon is greyed out, i looked online and I found this:
but that didn’t help. I don’t have my nodes reporting to a parent node and I don’t have a child node. I am just reporting directly to the cloud instance.
What do I do?
Hi.
Stale Node: A Child node that is no longer streaming data to its Parent, though the Parent still retains the Child’s historical data.
To investigate: Click the node’s info to view its Parent instance. If the node appears as its own Parent, this indicates the node’s GUID has changed (either through deletion or a bug).
Resolution: The removal procedure is the same regardless of the cause.
