This issue was brought up before but was NOT answered in what I would call a definitive way. When I attempt to look into what is going on with an alert, I can’t seem to do anything to respond to the presence of the alert and ‘quiet’ it. There does not seem to be any way to acknowledge it. I’m NOT looking to edit the alert which seems to be the only available option. The causes may be perfectly valid; I don’t want to edit that! But I do want to somehow acknowledge it and see if it comes back. In case anyone asks, the alert is shown both locally and in the cloud. To put it plainly, the documentation seems a bit sparse with how the alerting system even works. Is it collecting data from somewhere?
Hi @tgm,
What do you mean by ‘quiet’ it?
If an alert is raised and if you want to clear it, you need to solve the issue. If the alert in cause is not important for you, you can disable it.
