Connecting to netdata cloud showing "Invalid_otp"
I can’t connet my node to the netdata cloud. When I run the command “sudo netdatacli reload-claiming-state”, it returned as “Netdata Agent is claimed to Netdata Cloud, but it is currently offline: invalid_otp”. What happend to the netdata program ? How to solve it ?
Have run “sudo netdatacli reload-claiming-state” for several times.
System: Ubuntu 22.04 in Docker
Browser: Chrome 130.0.6723.117
Agent: v2.0.0
Successfully connect my node to the netdata cloud.
