@cjcox we don’t intend to disable a node’s access to the cloud from the cloud UI in the foreseeable future. Centralized configuration will start with alerts and then perhaps continue with data retention. We’ll discuss your suggestion internally though, it’s not something that had come up before.
What everyone else had always asked for was provided with the node deletion feature, which since yesterday has been greatly improved. If you access the space settings and go to Nodes, you see the following table that allows you to filter all offline nodes, mass select them and bulk delete them. No more deleting one by one and it works great for the “All nodes” room too.
