How to disable unwanted metrics
I have installated Netdata -v1.39.0 then i have so many resource monitoring But few are not needed for me so i want to disable few of then
Can anyone help to disable those provide me syntax of configuration and also provide location to store it.
Thankyou.
Please refer to this section on our documentation Common configuration changes | Learn Netdata
On a side note: v1.39 is old, current stable version is v1.45.3.
I have done Uncommented and changed the status from yes to no the plugin from the location /etc/netdata/netdata.conf related which i want to disable monitoring from the Netdata agent Dashboard after i was restarted netdata.
But no use of it in my case still it was monitoring in the netdata dashboard
I also tryed by removing completely and reinstalled still facing same issue.
Provide me any alternative way to disable from the dashboard from the configuration only i want to do.
My main Aim is to Utilize less configuration for monitoring.
ThankYou.
At first trail i was used v1.45.3 at that point also i was faced same issue!, So I have changed my version and tryed eith v1.39.
If you disabled the plugins and immediately go to the dashboard you still have past data collected, you should notice the charts for the plugins that you disabled not getting updated.
Could you show an excerpt of the disabled plugins and what charts you were expecting to not get more data for?
We are still trying to understand the issue because we’ve never seen the disabling of plugins not taking effect.
@ilyam8 's recommendation to be on the latest version applies since there have been a lot of improvements and bug fixes released since v1.39
I want to get only metrics from CPU,Memory,Network,and few APM remaining I wish no need to monitor from the dashboard likewise i need configuration
My moto is required things of monitor only required remaining should not be shown in mydashboard. Likewise I was thinking to Do !
By any chance is it possible.
I think we can’t provide more help @satyadeep777, the way to disable collectors is what was shared Common configuration changes | Learn Netdata
There isn’t any known or reported issue of the management of this not working and we don’t have any evidence from your side confirming that this isn’t working.
