Suggested template:
Could you elaborate a little bit more? Really we want to help you with your issue but we can’t understand your problem.
@Tasos_Katsoulas1 Thanks for your response.
I am working on setting up certificate monitoring, the jobs have been setup correctly according to the x509.conf file in my etc/netdata directory as guided by the documentation.
Problem is I cannot find a monitor showing the certificate stats and when I try to troubleshoot using the netdata user and ./go.d.plugin -d -m x509check i get the error below:
[ INFO ] main[main] agent.go:110 using config: enabled ‘true’, default_run ‘true’, max_procs ‘0’
[ INFO ] main[main] setup.go:67 loading modules
[ INFO ] main[main] setup.go:86 enabled/registered modules: 1/65
[ INFO ] main[main] setup.go:91 building discovery config
[ INFO ] main[main] setup.go:121 looking for ‘x509check.conf’ in [/etc/netdata/go.d /usr/lib/netdata/conf.d/go.d]
[ INFO ] main[main] setup.go:137 found '/etc/netdata/go.d/x509check.conf
[ INFO ] main[main] setup.go:142 dummy/read/watch paths: 0/1/0
[ INFO ] discovery[manager] manager.go:90 registered discoverers: [file discovery: [file reader]]
[ INFO ] discovery[manager] manager.go:95 instance is started
[ INFO ] run[manager] run.go:30 instance is started
[ INFO ] build[manager] build.go:106 instance is started
[ INFO ] discovery[file manager] discovery.go:71 instance is started
[ INFO ] discovery[file reader] read.go:39 instance is started
[ WARN ] discovery[file reader] read.go:63 parse ‘/etc/netdata/go.d/x509check.conf’: unknown file format: ‘/etc/netdata/go.d/x509check.conf’
[ INFO ] discovery[file reader] read.go:40 instance is stopped
[ DEBUG ] run[manager] run.go:41 tick 0
[ DEBUG ] run[manager] run.go:41 tick 1
Hope it is a little bit more detailed.
Thanks,
Sam.
Ok, thanks for the detailed summary, could you share your config (hide sensitive information)? Best guess a misaligned line or a tab instead of spaces in the config file (yamlish files are sensitive to those)
[minor] did you use the edit-config script right?
Tasos.
@Tasos_Katsoulas no tabs were used in the config file just the deletion of the # signs to activate the jobs.
Ok I would love to see that config because there are many things that may have gone wrong
Just two more things to take into consideration:
IMPORTANT:
- Parameter ‘name’ is mandatory.
- Jobs with the same name are mutually exclusive. Only one of them will be allowed running at any time.
- You comment in the “jobs” section in the end of the config file, right?
@Tasos_Katsoulas I will work on that and provide feedback.
